Why am I not at all surprised to learn that you have a lot of experience of encountering people who do know what they are talking about trying to get you to understand that you do not?Coming up against people like you, well it’s ten a penny.
I can believe that.I’ve always been told I can’t do things, I’m incapable
More determined to learn, or more determined to blunder on?and it just makes me more determined.
OK. If you promise that you will go away and use the information properly.you haven’t provided any information that has helped me or anyone else.
The thing is, rewiring a house, installing a CU, etc is not a trivial job, and I can assure you that it involves knowing far more than you think it does.
Asking questions here can be a useful part of a learning process, but they are not a substitute for proper structured studying. The key term there is "learning process" - you cannot learn all the things you need to know just by asking questions here. It isn't structured enough - it won't provide you with a way to progress where each step builds on what you learned before.
You can't carry out a job of this magnitude by asking whatever random questions happen to occur to you. You've already shown that you have some dodgy misconceptions - what if you get something wrong because you have no idea your knowledge is wrong? What if you miss something because you simply have no idea it even exists, and just don't realise you don't know it?
- http://www.diynot.com/wiki/electrics
- http://www.diynot.com/wiki/electrics:books
- http://web.archive.org/web/20080213151445/http://www.kevinboone.com/electricity.html
- http://www.tlc-direct.co.uk/Book/1.1.htm[/list]I suggest you get stuck into the last link right away - it won't give you design ideas, and unfortunately it doesn't refer to the current edition of the Wiring Regulations, but it's free, and will still give you a good grounding which you can augment with more up to date publications.
Because you can't.All you've said is ''get someone to do it''.
You really can't.
Hang on - I'll go and look in the mirror, and will report back.You’re foaming at the mouth over petty definitions and correct terminology like you’re some kind of construction wizard.
I've not posted anything inflammatory, extraneous or off-topic with the deliberate intent of provoking you, or anyone else, into an emotional response or of otherwise disrupting normal on-topic discussion.I wouldn’t troll someone’s thread
So you recognise that you clearly need help and lack knowledge, but seem totally unwilling to see your helplessness and ignorance as reasons why you can't do this rewire yourself.because I didn’t like their tone, besmirch and belittle everything they are trying to do, despite them saying they clearly need help and lack knowledge.
Several posts of yours here give a very firm indication that the opposite is true.I hold the regulations in the highest regard and I want to do the job properly
Going to do the runs with the neighbor and have it tested separate lolIf you mean that to get self certified you need the electrician to do the whole job then who I get to check it all over and test will certify it .. why would I pay some rusty old pedophile council worker to come out ?Why would I need a designer for christ sakeAnd no I won't pay when I can run wires myself and pay for the connections.I would notify building control if they offered a consultation service that I already pay for as part of council tax. The work will be inspected and signed of by a qualified electrician.It's not against the law and you don't need a doctorate to run dead cable. The entire system will be inspectable from start to finish, no boards fitted back, no connections covered up. I don't care if you're not happy with this, no pleasing some people
