Just in case anyone thinks 183m is a strange figure for a statutory regulation, it is, of course, 200 yards.
As you say, it probably happened because there was no suitable alternative. However, if you want to look for a physiological rationale, IIRC, low-light-level human vision (using 'rods', rather than 'cones' in the retina) is most sensitive to the green/yellow part of the spectrum, and relatively insensitive to the blue part of the spectrum. Just a thought (even if it may well have been 'fortuitous'!)!Might be as true as the French reasoning for having yellow headlights all those years. ... But I think we had sodium lights because that was basically all that was suitable ....
LED street lamps are being trialle my village, main advantage is lower running costs.You're not going to believe this but I've just been outside and they must have been round and replaced the street lights with LEDs
Changing the colour of street lightning at a junction or hazard was once used as an extre way to alert drivers of a need for more attention. I don't know it is was an official policy to do so or just a bit of common sense thinking by a few officers in a few local councils,The main road at the end of the street is totally bathed in a lovely orange glow.
That's an easy question to answer - nobody expects street lights to be on during the day, and nobody thinks that speed limits do not apply in the day.As to disused lamp posts I don't know. We have always had timers which switched of street lamps after midnight so I would think simply not being lit would not make a 30 MPH area unrestricted but I would think there is a time limit to repair broken lamps and if simply switched off it would raise the question did this mean the speed limit was also removed at the same time.
Traffic Advisory Leaflet 09/99 (20 mph Speed Limits and Zones) (DETR 1999a) gives advice on how and where to implement 20 mph speed limits and 20 mph zones. They should not be implemented on roads with a strategic function or on main traffic routes.Flintshire has said they are putting 20 MPH speed limits outside every school but to do that means they also have to put in traffic calming which will cause problems on main roads.
We have the technology to implement variable speed limits, so we don't, for example, have 20mph zones because of a school when there's nobody using the school, or where we do need them when the shops are open but between midnight and 5AM they could safely be 40mph, and to simultaneously ensure that if you break the speed limit you WILL get caught. It would require equipment in vehicles, but within a generation or less we could, if we wished, virtually eliminate speeding.Also the lighting has to comply. Easy to fit signs it's the rest which causes the problem.
