Help needed replacing switches
10 Dec 2009
Middlesex
I have a couple of switches that i want to replace and had some questions:
first is the bathroom/hall way switch.
i have 2 hallway lights controlled by two switches at either end of the hall. A 1 gang 2 way switch at one end of the hall way.
At the other end of the hall next to the bathroom is 2 gang 2 way switch which controls the hall light on one switch it also controls the bathroom light and bathroom extractor fan off the other switch.
The extractor fan comes on with the bathroom lights and has a fixed live to keep the fan on overun when the bathroom lights get switched off
Ive bought a 2 gang 2 way 10ax switch to replace the switch at the bathroom end of the hall.
I thought i had wired everything up correctly but the bathroom extractor fan comes on and remains on even when the bathroom light is not switched on.
Other than that the hall way lights go on and off fine, as do the bathroom lights. I just cant work out where ive gone wrong with the fixed live for the fan.
Heres a picture showing the old switch on the left hand side and its exising wiring. The arrows indicate where i connected the wires on the new switch shown on the right. doing this causes the bathroom extractor to be permanently on regardless of the bathroom or hall way lights
Can any one help out with this one?
Second is the fused power switch for my combi boiler.
Ive bought a 1 gang switched fcu to replace the old switch.
Heres the old switch
View media item 80473
VS the new one
View media item 80474
All the connections look correct but i noticed that the old switch has a 3 amp fuse in it. ( even though it says on the back has 13/20 amp 250v)
is this safe/correct? The switch has not been touched since i moved in.
The new switch comes with a 13amp fuse so i just want to be sure of what fuse i should be using before i change the switched
2 way switching will use all 3 switch terminals.
The bathroom 1 way will only use 2 terminals.
There are you sure it's labelled correctly?
Use the 3a fuse for boiler
Use a 3 amp fuse for the boiler, the info on the back of the fused switch is just the maximum rating for it. (i.e it can take up to a 13 amp fuse.)
For your lighting, the cable with the red, blue and yellow wires is the cable for your 2 way hall light. The cable with the red and the black wires is for your bathroom light and fan.
For wiring your new switch as in the position and as shown in your photo, and viewing it as having 2 terminals on the top and 4 terminals on the bottom. (it's really two 2 way switches)
The yellow wire from the hallway light cable should go in the top right terminal
The red wire from the hallway light cable should go in L1 on the 3rd terminal from the left.
The blue wire from the hallway light cable should go in L2 on the 4th terminal from the left.
The red wire from the bathroom light cable should go in the top left terminal
The black wire from the bathroom light cable should go in L1 on the 1st terminal from the left.
Don't forget your new switch requires earthing.
There is nothing on the switch which would alter the fan operation.
That's what he's done (well - using L1 where you say L2, and vice-versa, but that will only affect the rocker orientations, not what the switch does).
Rob - what happens if you put the old switch back?
EFLImpudence; true - but he may have thought the switch was off when it was on, thus is always better to use L1 when the switch is in the correct way up.
ban-all-sheds; I know it makes no difference to the way the 2 way switch operates, but common practice to wire red/brown to L1, blue/grey to L2, and yellow/black to common.
I left earthing out for simplicity reasons, as it is common sense.
May be the fan has developed a fault?
Am I missing two things?
1. I can't see any red/black to which people refer in the bathroom switch terminals.
2. If the blue of the bathroom fan wiring is a N, it will cause a big bang if wired up as it is in the white switch.
Indeed. But he reports the bathroom light as going on and off, so he knows when the switch is on and when it's off.
The wires don't know what legends the terminals have.
How do you know that the other 2-way switch has been wired the way you suggest?
It's not. The switch on the left is the old one, and it doesn't go bang, and it works fine. The OP has got confused about which cable is which, and what each core is, because he doesn't actually understand how any of it works.
True, and i don't. Just if you were doing a new install you would use a standard and convention.
600rob, have you tried taking the switched live wire out of the extractor fan and seeing if it still starts.
that's what I thought
I've replaced the old switch using the original wiring configuration as shown in my original pic.
Everything works correctly with the old switch...
Bathroom lights switch on and the fan only comes on when the bathroom light is switched on. It remains on overrun as per its setting then switches off.
Hallway lights are all fine
