Hi everyone,
I have been on this forum for a while as a reader but i had to join as i run into a problem while trying to put a new light in my room..
I want to change my bedrooms 1 gang switch to a 2 gang switch, then run a new cable from the switch to a new light (hopefully sharing the live from the existing light at the socket).
BUT... the light switch in my bedroom shares the same cable as the sitting room light switch. Both rooms light switches are directly back to back, so if i open my sitting room light switch, directly behind it there is a hole which feeds a shared live and the neutral to my bedrooms switch.
I am completely baffled because the neutral is only used for my bedroom and is not shared or connected to the sitting room switch..
I have provided pics below. The switch with the ground cables is the sitting room switch then you can see where the shared live and single neutral are pushed through the wall, where it is connected to my bedroom switch!
