Cat5 305m?
25 Jun 2008
Manchester
Just having a discussion about this at work and still can't find the answer, does anyone know why data cables cat5/6 etc come in 305 meter coils.
Is this something to do with the max length of signal it can carry or something?
Seems a very specific number?
Because it's 1000 feet. ;)
100m is the recommended maximum run - or 90m with 10m patch allowance is sensible. This is assuming a basic 100Mb network on CAT5e.
Bloomin Europe ... What was wrong with Rods, Poles and Perches??
Quite so. The three are, of course the same, and maybe the Cat5e drums were meant to be 60 rods (or poles or perches) - with just a little spare for the terminations!
Yeah, what could be simpler?
As a unit of area, a square perch (the perch being standardized to equal 16 1⁄2 feet, or 5 1⁄2 yards) is equal to a square rod, 30 1⁄4 square yards (25.29 square metres) or 0.00625 acres, or 1/160 acre. There are 40 square perches to a rood (A rectangular area with edges of one furlong (10 chains i.e. 40 rods) and one rod respectively), and 160 square perches to an acre (an area one furlong by one chain (i.e. 4 rods)). This unit is usually referred to as a perch or pole even though square perch and square pole were the more precise terms. Confusingly, rod was used as a unit of area but it meant a rood.
However in the traditional French-based system in some countries, 1 square perche is 42.21 square metres.
- Wikipedia.
The Imperial system of measurements was adopted by the United States (with slight differences in pints and gallons due to, IIRC, George III). Whereas we have complied with the will of the "thick" Europeans who can only multiply and divide by 10, the Yanks, thank goodness, have resisted the metric system. I remember learning 16ozs=1lb, 14lb=1stone, 8 stones = 1cwt, 20cwt= 1 ton. Also 12ins= 1ft, 3ft=1yard, 22yards=1chain, 10 chains=1furlong, 8furlongs=1mile! 1 mile = 5280 feet or 1760 yards.
They put a man on the moon using yards, feet, inches, pounds and stones. Stuff yer meters and kilos!
Do you remember those old school exercise books that had all of that stuff on the back cover…….??
Even if I could not remember, I still have some (with aged red covers, and containing my 50-something year-old writing) to look at to remind me :)
I remember learning 16ozs=1lb, 14lb=1stone, 8 stones = 1cwt, 20cwt= 1 ton. Also 12ins= 1ft, 3ft=1yard, 22yards=1chain, 10 chains=1furlong, 8furlongs=1mile! 1 mile = 5280 feet or 1760 yards!
But what about pottles, pecks, tuffets, strikes & combs?
