I have a 2003 Rav4 (140,000 miles) that was recently rear ended. (10 to 15 mph collision). It started and drove away from the wreck with no issues. The next morning after dropping off kids, it died in the middle of a busy intersection with no warning. Cranks but hasn't started since.
I've pulled the back seat, listened for fuel pump sounds with key on but nothing. Metered the 5 pin connector and have 11v on 2 pins (battery is slightly down from trying to start it). And, 8.8v on the other 2. See pic. Not sure of the actual pin numbers...just there for visual reference.
Not sure what the other connector/wires on the pump do or should read. See pic.
Anything else I should check before replacing the pump? I thought I would pull it, air dry it and use a 12v bench test supply to see if it runs out of the truck.
Peace,
Mark
Peace,
Mark
