just have some questions which im abit unsure about.
when wiring swa cable up to an outdoor socket, how do you actually earth the steel in the cable. the outside socket has 2 earth links. I assume one of the cores for the swa goes into 1 link, then what about the steel wire? does this connect up to the other earth by using some core to attach to the banjo ring?
the double socket is to power my pond pump and filter. they draw a combined 36watts. so would 1.5 or 2.5mm core be used?
btw, im not intending to do this myself, just curious. will have an electrician sometime later this year to install it all for me
