Can now see 2 sleeved earth wires pushed up into the ceiling.
Can you see where those earth wires come from? Given that there are four cables (which should mean four earths), I wonder if there might be two earth wires (each coming from a different white cable) inside each of those two bits of green/yellow sleeving - making the four in total.I found 2 earth wires running into a connector.
Yes, I imagine that's what he meant - and that would be fine.I take it you mean I can get a small length of earth cable, connect it to the other end of the connector and run it down to the light and that’s fine?
Thanks for confirming.Hi John, I just looked and it is indeed 4 in total split into 2 sleeves.
See EFLI's answer - you just need to find some spare/old bit of flex to steal a little of the green/yellow core from (or take the bare earth wire out of a spare bit of twin/earth cable and put that inside some G/Y sleeving).Is this the type of thing I need?
