Security light not turning off
6 Dec 2007
Dundee
We've got a separate security light/pir sensor and all of a sudden, it's not turning off.
Nothing has happened (ie bulb blowing, power cut or anything like that) that might have caused a problem - it's just decided to come on and stay on.
Is it likely that the pir has malfunctioned and needs replaced?
We've got a separate security light/pir sensor and all of a sudden, it's not turning off. ... Nothing has happened (ie bulb blowing, power cut or anything like that) that might have caused a problem - it's just decided to come on and stay on. ... Is it likely that the pir has malfunctioned and needs replaced?
Are you sure that it hasn't got into a 'manually on' mode, perhaps due to a very brief (fraction of a second) power cut?
If you have a switch or isolator which controls the light/PIR, try turning it off, leave it off for a short period (anything more than 10-15 seconds) and then back on. If you do that, the light may immediately come back on and stay on for it's timed period (whatever that is set to) before going off - so don't immediately assume that it hasn't worked!
If that doesn't work, you probably need a replacement PIR.
I'm not sure about a manually on mode :? I tried switching it off at the isolator, left it, switched it back on and waited - it didn't go off. I've had to just switch it off altogether just now cos it was shining right into the bedroom.
It sounds as if you probably need a new PIR then.
Many PIRs have a built in 'manually on' ('over-ride') mode. To implement that, you switch it off (with isolator or whatever) and then immediately back on (within a second or so) - and that makes the light come on permanently until you switch it off. As I said, things like very brief power cuts can emulate that rapid off-on switching and therefore put it into that mode. However, it sounds as if you have excluded that as a possible cause of the problem.
Thanks John. I'll check it again. I switched it off at the isolator and I've not had a chance to get a new one yet but maybe I switched it on too quick when I tried testing it, so I'll do it again and see.
Originally, it was off and I went out and it didn't switch itself off again.
Ahh I left the security light switched off and hadn't got round to getting a new PIR but I thought I'd check it again - and lo and behold, it worked.
Now it's just malfunctioned again :? so I guess I'd better go and get that new PIR.
Ahh I left the security light switched off and hadn't got round to getting a new PIR but I thought I'd check it again - and lo and behold, it worked. ... Now it's just malfunctioned again :? so I guess I'd better go and get that new PIR.
Hmmm - it does sound a bit iffy, I agree :-)
