Hi there,
This has happened twice. Removing very old sockets on a refurb and found it impossible to put a new socket on with the flex available. I think the sockets must have been connected and then the wires pulled tight from the wall behind, leaving tiny amounts of wire to play with.
My workaround solution has been to use 30amp strip connectors and a bit of 4mm to extend the wire. In the first case, this has ended up being enclosed in its own box with the extension going directly below to a new socket. In the second, there is plenty of room for the whole thing to fit behind the new socket.
Does this setup pass muster for any future inspections? Any advice? All connections are sound and everything in sound mechanical condition.
Thanks,
M
Thanks,
M
