How to remove JCC led lights
26 Apr 2011
Surrey
Hi guys,
Im about to board the loft. The bathroom which is underneath the loft uses these lights: http://www.jcc.co.uk/products/fgled6-mains-dimmable-downlight-warm-white-4/
Should the lights malfunction, how would I replace them? Do I need access from the top (in which case Ill need to allow for that when boarding the loft) or can they be replaced from below - which will mess up the pasterboard ceiling?
I hope that makes sense.
If you read the installation guide within the link you have given, contained in download tab. It will inform you how to install them and uninstalling will be the opposite method.
While you are looking at that download. Please pay attention to the second page which will tell you the clearances and ventiolation requirements for the lights.
Before you do, build (or buy) sealed enclosures to go over the lights which provide the clearance that the maker of the lights specifies.
http://www.nhbc.co.uk/NHBCPublicati...ical/StandardsExtra/filedownload,16553,en.pdf
http://www.aico.co.uk/downlights-in-loft-space-what-to-fit.html
Allow for it anyway - you should not make the wiring inaccessible, particularly if there are any screwed cable joins.
