Hi all
Drained system today as I needed to move hot & cold pipework for new kitchen.
All went well until refil, whereby it now seems I have either an airlock or a problem.
With 3-port valve set to MAN I have expect the system to refill (F&E tank is full), bleed valve on rads open and can hear hissing for a short while before stopping, but no water either coming out. Drain plug beneath pump opened and no water coming out.
Having a look at f&e tank piping, it seems it has been changed at some point and the outlet seems to go uphill slightly, and not sure it this is causing the system not to fill. I have added pics which hopefully help. The outlet seem to be changed to go into the expansion return pipe, as there is another 15mm pipe that has been cut and left in situ.
Any ideas, Im starting to get annoyed with this. Only had the house a week
Thanks in advance
Thanks in advance
