Low voltage transformers
17 Aug 2010
we have a display cabinet that use 5 x 35w 12v bulbs that are on a track. The 200va transformer has died. I have quite a number of 105va transformers that are no longer used. Could i link two of them together in parallel ? I really don't want to spend £20 on a new 200va transformer.
No, the output is AC and there is no way to synchronise the waveforms from two separate units.
Transformer and electronic transformer are very different beasts. Using 2 identical transformers could work assuming connected in phase but two electronic transformers which are really switched mode power supplies would not work.
Better to either split the load or buy transformer which can take full load.
I was replying to nozzle, but he's decided to remove his post for some reason :roll:
