Good morning ...I have no clue about Central heating or boilers.....but before I call an (expensive) engineer I thought I would just ask on here for some advice/guidance please....thank you.
I have a Boulter Buderus boiler installed in a new build house in 2006. Last night I had the room thermostat set at 16 deg. but all the rads that were on were too hot to touch.....I only have 4 of the 10 rads turned on. Each rad has a TRV (apart from the "master" rad in the hall).
The boiler was showing rad temp at 82, was venting fine and the condensor drain is not frozen or blocked.
Anyone any ideas please?
Thank you so much.
MrsMac03
Thank you so much.
MrsMac03
