Old light fitting mains plug
Rega
Linn
Pro-ject
ClearAudio
Pink Triangle
Michell
Pick your choice from eBay and you won't be disappointed.
Unlikely to get makes like the above for £60 though.
Don't pick anything with a return mechanism
That can usually be removed.
Which is what I'd suggest doing with this, if you want a player for £60.
www.ebay.co.uk/itm/JVC-JL-A20-Belt-...le-M75-EJ-Pick-Up-Cartridge-P-C-/221647592941
There are currently about half-a-dozen reasonable decks on eBay right now, auction items, with the price currently in the £50 - £100 bracket.
These discussions about alternative equipment are all very interesting, but has anyone noticed that the OP has not been seen since 5 minutes after his initial post, nearly 3 days ago? :-)
Attack of the live chassis?
Possibly! However, probably more likely, as soon as (after a couple of minutes) he read the answer he wanted to hear ...
You can use a normal plug with a 3A fuse yes.
... he probably didn't bother coming back to the forum - and hence didn't see all the other discussion and advice about his equipment, and alternatives!
Yes ! i thought i hope it's not a HMV record player ! I was bitten by one as an aprentice as it had a non polorized fig 8 flex and a 2 pin clix plug , i was just unlucky ! :roll:
Regards,
DS
Indeed, but that was almost par for the course for all consumer electronic devices (radios, TVs, record players) back in the 50s and 60s - the chassis connected to one side of the mains supply, via a 2-core cable (with or without identifiers) and often a 2-pin plug (sometimes a B22 one!) or, at least, no attention/interest as regards which way around a 3-pin plug was wired!
Yes, but there was an earth ! taped to the outer sheath which i connected at the bench during repair, my boss then stuck a screw driver into the pick up socket and well……. very similar to you're 25w candle lamp we were in darkness :shock:
Regards,
DS
Ah! In retrospect, I suppose one of the reasons why all those live-chassis items were not a lot more lethal is that there was usually no earth in sight.
Happy New Year!
And don't forget that some valve radios had a three core lead, Live Neutral and a resistive conductor. The resistive conductor was in series with the valve heaters to control the current through them. When the valves were getting old and less emissive ( fewer electrons leaving the cathode ) a quick fix was to run the heaters at a higher temperature, shortening the mains lead achieved this.
Replacing a worn mains lead with normal cable ( without the resistive conductor ) would burn out at least one of the valves.
