I have a Honeywell 7 day programmer (controls water and heating independently) and has 3 on off periods.
The installer installed this with a Drayton wireless room stat.
It was suggested to me that I upgrade this to a programmable stat so I have a Drayton 7 day programmable thermostat now (uses the same receiver).
I programmed the stat to the on/off periods and temperatures required. Generally the winter so far has been mild such that the reading on the stat has been at the level programmed. Therefore I would expect the heating to be off.
However it seems to be on at times I would not expect, particularly at night time.
I have left the honeywell boiler prog at the same on/off settings as before as assumed the stat would over-ride this if required?
I did have the programmer on constant but this seemed worse.
How should I have this set up?
Regards
Ed
Regards
Ed
