- Joined
- 27 Jan 2008
- Messages
- 29,247
- Reaction score
- 3,588
- Location
- Country
We have traditionally treated our household AC supply like DC and ignored balanced feeders and transmission line rules.
With twin and earth the line and neutral are nearly the same spacing as 300Ω feeders and if we take the supply to the switch and then to the lamp everything works OK.
But traditionally we take supply to lamp and then only the line goes to the switch and this can cause LED's to remain lit dim and CFL to flash because the capacitance and inductance in the cable no longer match.
I am about to start re-wiring my mothers lights as there are no earths and for simple switching taking supply to switch is OK but for two way it would make it rather complex and also increase the volt drop.
I am a great believer is standard so when some one comes to repair it's wired as expected and also no point in re-inventing the wheel.
So in the view of using LED lighting has there been a change in practice where neutrals are run with live to stop lights coming on dim.
I am aware one can use inductance and capacitance to correct the out of balance and fitting suppressors is now common across the lamp when LED is retro fitted. But what about when starting from scratch is there a new standard method of wiring which keeps neutral with line to stop the dim light caused by ignoring transmission line rules?
