here's a pic after I've sorted out some of it. A whole load of wires & the junction box that was on the left have been removed as they are not required.
But never mind - it isn't the guy below you who is at risk, it's you, so if you don't give a toss if you die in a fire which started in his flat and spread to yours because the conversion is dangerous and illegal, why should anybody else? Do you live alone, or is your lack of concern for your safety going to have life-changing or life-ending consequences for other people?
I don't know how Part E relates to modernisation of flats; safe to say I won't worry about it.
Well maybe someone could point me to some regs cos as far as I know no-one uses fire rated plasterboard as standard when doing up properties, except for protecting specific areas such as RSJ's, and I don't believe that it's use is required for standard ceilings.
I really don't think standard plasterboard is a) dangerous and b) illegal. I've just spent about 3 mins reading and it would appear standard plasterboard actually behaves in a very secure way in fires. In fact British Gypsum state their standard wallboard is
'Suitable for most applications where normal fire, structural and acoustic levels are specified. Suitable for direct decoration or Thistle plaster finish.'
and
'For the purposes of the national Building Regulations, plasterboard is designated a ‘material of limited combustibility’ (Approved Document B) The surfaces of Gyproc WallBoard are designated Class 0 (for the purposes of national Building Regulations). ' etc
For how long does it behave in a very secure way ? Long enough to allow you, in the flat above the fire in the flat below, to realise there is a fire and you need to evacuate the building. ?
If the people in the flat are out when the fire starts then there will be no clear indication to you until the fire barrier between the flats is breached.
