Just one example:
http://www.rselectricalsupplies.co.uk/switch-module-push-onoff-md9001_7788[/QUOTE]
Ok, so how does that make the finished product look?
I.e. if we bought the following product from B&Q (i.e. a double rotary dimmer switch):-
http://www.diy.com/departments/vole...tary-dimming-250w-dimmer-switch/109119_BQ.prd
and then replaced the rotary dimmer module with the on/off switch module (as linked in your post above), I take it that would solve the problem “behind the scenes” so to speak i.e. the bit of the light switch that we don’t actually see. However, what does the front of the double switch then actually look like? Does it end up looking like that industrial set up in the attached picture below?
Or can we get a finished product that would have a nice chrome rotary dimmer switch facing (on one side of the double switch), and the (exact same chrome finished) on/off switch facing (on the other side of the double switch)?
If so, presume we then need to purchase the following product to cannibalise the on/off switch facing in the exact same chrome finish?
http://www.diy.com/rooms/colours-ch...ght-switch-1-gang-2-way-sp-10ax/173655_BQ.prd
If this is the case, then how on earth do we get the on/off switch into the double dimmer casing?
Still very confused!!!
