Having just had some fitted furniture ripped out from a bedroom, this lot appeared! I'm assuming it is illegal on at least a couple of counts - cables not running in the correct locations and the junction box not normally being accessible. Am I correct, and does this lot need replacing?
And what's this? I found it under the floor of the same bedroom (ground floor - it's a bungalow). At first I thought it must be an original installation from when the house was first built (1920-1930) and now disconnected, as it is nowhere near the present CU and meter and looks ancient. However, holding a Fluke VoltAlert next to the metal box and next to one of the cables, it lights up suggesting the unit is still live.
The cables enter the metal conduit shown, which appears to head towards the back of the house and not the meter and CU, although it could turn a corner and head over that way. The metal conduit looks similar to that which carried the cables to the meter, shown here:
I may be wrong, but it looks like the metal conduit provides the earth connection. If so, and this is the same conduit that appears under the bedroom floor, I can't see any obvious earth connection at that end.
Should I be worried?
