He'll be on his way as soon as he's had a bath.My wife sends her love!![]()
I think he's probably talking about an external 'meter box'. mounted on an outside wall of your house.But what is a 'surface mounted viewing cabinet'? Is that some modern equivalent to the old metal box under the bedroom floor? I assume there would be sufficient space for it on the board next to the meter and cutout (see earlier pictures).
You're welcome. They're common. I think they have probably 'standard' for new builds for quite a while, although they can then easily be recessed into the wall ('flush'), whereas with an existing building, it's far more practical to install a surface-mounted one.Oh I see. We already have an external gas meter now, so I suppose an external electrickery meter is logical and they wouldn't have to come in to read it. I didn't know they did them, though. Thanks.I think he's probably talking about an external 'meter box'. mounted on an outside wall of your house.
I suspect that depends a fair bit on the material and construction of the wall!It doesn't take long to cut a hole to fit a near flush mounted box ready for the DNO to install cable and cut out. Makes a much neater job. DNO cable runs up the front of the wall and into the "rim" of the box.it's far more practical to install a surface-mounted one.
Sorry - I forgot you were from Yorkshire.
Yorkshire bath:
Cheshire bath:
London bath:
Indeed. For example, I don't think I'd want to try it in either of my daughters' houses - one has a stone-built cottage (and, anyway, Listed - so a meter cabinet would probably be a no-no) and the other is timber framed.Yes I accept that I should have said "depending on the type and condition of the wall cutting a hole for a meter box may not be a big problem."
Just out of interest, why do both you and SS think it unwise to re-use the present conduit?
What does that mean?
Depending on the house construction that can lead to a lot of grief.
I know of one or two where it ended up with part of the house wall needing rebuilt so I would never recommend it.
Also in this case the cost of that would fall to the customer, whereas, if I were doing it, with an surface mounted cabinet, there would be no cost to the customer.
The actual route of your service as shown on our records, so extending it would not be an issue
Note that this plan is not to scale so should only be used as an indication of any cable route
