Hi all,
I know this is a simple task but I'm sure I'm doing something wrong! Let me start off by describing my system - I have a F&E heating system with a hot water tank in the airing cupboard, Gloworm 60FF boiler, 7 radiators (3 upstairs / 4 downstairs). And just to give you some background information - my heating system had poor circulation due to sludge build up (just bought the house, previous owners obviously didn't use any inhibitor) so I drained the system (to do some unrelated pipework), then took off every radiator and flushed it through with a hose.
I then refilled the system, and bled all radiators starting with the ones downstairs then moved up. After this I switched on the heating, and repeated the bleeding process as the radiators now had some pressure from the pump. Now here's where I'm struggling, I have some old radiators with the bleed valve pictured below, and I'm finding I'm having to almost pull them the entire way out and jiggling them about before I hear any air escape. After a few minutes of doing this the radiators start to get warm but they never seem to get hot like they used to (even though the flow pipe is boiling!) and I have literally tried bleeding them for 10 minutes with no luck. Am I doing something wrong? If I can still hear hissing, does that means there is still air in there? Also is my bleeding process correct?
Any help would be greatly appreciated
Cheers
Hitmo
Cheers
Hitmo
