I'd have a slight concern that 75mm of insulation wasn't very much - sure it meets building regs, and in a standard rad-heated house increasing the floor insulation has only a negligible effect on heating costs..
..but remember that in this case your floor is your radiator, and the only thing stopping the heat disappearing into the ground is the insulation. A 75mm slab of screed will also have quite a thermal mass so youre going to be looking to heat it continuously - make sure the rest of the insulation in this extension is up to scratch and really work on sealing all gaps and draughts so the generally lower temp that it runs at still realises a comfortable room
You rightly point out that the floor surface is the radiator but the fact that some (more) of the heat goes into the ground if inadequately insulated doesn't affect the ability of the system to heat the room...it just increases the losses for sizing the boiler.![]()
