I need to add a single mains socket in a room for TV/SKY and the only power source in the room is a switched FCU which is a spur of the ring main.
The switched FCU is for a macerator pump but the FCU is installed outside the bathroom.
I would like to run surface mounted/1.5mm flex clipped to the wall from the FCU (load side) to a surface mounted single socket. The cable run will be 10m and i would like to replace the switched FCU with one with a flex output to make things easier.
Is this the best/correct method?
