I'm about to buy some fitted wardrobe cabinets from http://www.diywardrobes.co.uk - and I just need a little advice regarding the frame.
The wardrobes are 2800h, 2900w, 600d
I was thinking of using kitchen unit plinth feet to set my wardrobes on to give me the flexibility of levelling whilst I was building it, but these are around 150mm high, and my top and bottom plinth will be 80mm each (and I want them the same).
My next solution is to simply span a 3m length of wood across the floor, 80mm high, and ensure it is level. I will offset it 18mm back and then stick the scribe pieces to the frame to achieve the fitted wardrobe look.
Any suggestions on what I'm about to do, and if there is a simpler way? I've never done this before.
