Thanks. The two neutrals should be both be connected to the 'N' terminal of the PIR, as you seem to have done with the two black conductors.Hello John, here is the instructions http://www.free-instruction-manuals.com/pdf/pa_426718.pdf
the live wire is coming down from the ceiling where a standard pull cord light switch was. ... so I can easily wire the mains into the unit the bit I don't understand is where does the neutral wire go from the wire running to the light?
You must get a neutral, as well as live, feed for the PIR. As I said, it's pretty unlikely that will be a neutral available at the light switch, so you'll probably have to re-route that cable so that it comes from a light fitting or ceiling rose, rather than from the light switch.I think I understand but I cant see any other wires and I obviously don't want the sensor next to the light, is there no other way of doing this?
? can you tell us please?Were both of those two cable originally connected to the pull switch, or have you added one?
Do you have a multimeter?
That's all assuming that the incoming black is actually a neutral - which is far from certain and I would personally think pretty unlikely.My guess is that the red connected to Live in the three way block is the Switched Live to the lamp. The other red, connected to the two way block is the incoming LIve supply. ... Since the contact in the PIR will be open until it has power the Live from the PIR's LIve terminal is not going to be Live hence the PIR cannot operate. ... Try exchanging the reds.
The question relates to the black coming from the ceiling pull switch (along with what is probably a permanent live in the red). It may be connected to nothing or, I would suspect more likely, may be connected to the switched side of the light switch - in that case, if it is an SP switch, when the switch was on, both red and black from the switch would be at 230V, so no surprise that nothing worked. However, that's all pure speculation.If the blacks are not Neutral then what are they ?
Despite questions and comments, there has been no mention of a ceiling rose.If one cable [X] is Live and Switched Live from a ceiling rose with looped neutral ....
That's possible. As has been said by others, we really need to know where those two cables come from and see photos of what is going on at the other ends of them.Perhaps the OP can tell us how the pull switch ( now refitted ? ) has been wired. It could be a double pole switch if all 4 wires are connected to it with both Live and Neutral being switched.
