Hi, sorry to interrupt everyones sunday lunch but just hoping to get a bit of advice.
as the title says my vokera vision C has stopped working and is showing an A08 fault code, I`m going to type out exactly what the instructioin manual says.
A08 cause- return thermistor fault- action-check return thermistor, check wiring
cause- return thermistor over temperature- action-reset, check appliance operation
cause-temperature differential inverted-action-reset, check pump, ensure there is sufficient circulation around heating circuits
as you can see there are three possible faults, is there anything I should be doing to remedy this or is an engineer call out needed.
many thanks in advance
