Insulation resistance test..
If you test on the load side of an RCD, with the RCD open., would the test voltage still
Go through the RCD sensitive bits?
Basically which side of the switch is the sensitive stuff on.
As you should not carry out an insulation resistance test through an RCD, but may want to test the whole installation, what ways can this be done.
Thanks[/list]
Thanks[/list]
