I know it's a bit of a long shot but can anyone tell what rating the cable on the left might be? The cable on the right is modern 2.5mm t&e. I should say there are no markings on the cable at all.
http://s1157.photobucket.com/user/normanbrooks1950/library/
Each conductor is made up of 7 strands, and it's connected to a 32a breaker. It supplied the cooker in a 1975 build house, and I'm wondering if it would be up to supplying a new oven and hob. The hob is rated at 7.9kw and the oven from a previous posting appears to be 2.5kw. The cable is under about 10 inches of insulation in the loft, but underneath it is up against the ceiling plasterboard. If it's up to the job would it be an advantage to lift it above the insulation, and clip it to the roof trusses?
