- Joined
- 17 Jun 2015
- Messages
- 10
- Reaction score
- 1
- Country
What do you mean by IT earthing system?All plugs were tested using a plugin tester, wiring colors followed and earth indicator in place. Only test left is RCD trip out and to get it certified.
Hi All,
I am doing a trial project and I would like to know if this type of radial circuit would be acceptable and certifiable.
All cables and junction boxes are secure.
Best Regards,
Jackson
No it doesn't. How did you comply with Part 6?All electrical is currently conforming with BS7671 and and 17th edition wiring regulation.
As has already been stated the diagram is a radial final circuit - though no self respecting electrician would introduce additional terminations into a circuit without good excuse.My only concern at moment is regarding diagram comply with wiring regulation and it would pass inspection.
I feel offended!!!Thank you everybody for your comments specially for Ericmark for answering my question.
... Earthing is TN–S.
I must be missing something - what started these questions about IT earthing systems?Still awaiting a reply regarding your IT earthing system.
Ah! ... I guess there's a lesson to be learnt there - it's the reason why, personally, if I am questioning or referring to something someone has posted, I always quote it - just in case they subsequently edit their post, and hence thereby potentially make nonsense of what I have written/asked!The OP changed his post from IT to TN-S in post #4 it says Last edited: Today at 10:23 AM
At least does show where he is looking and quite valid a plug in EZ150 tester only shows better than 1.50Ω and so does not give a 100% answer as to if it passes. Can't remember new limit for a ring final but not talking about a ring final and 16A spur is around the 2.73Ω mark so good enough.No it doesn't. How did you comply with Part 6?
