Yes If i made that, i would not admit to it……..Yes, aware of what I would need to purchase in order to replace it, thanks.
There is no indication of manufacturer on any of the switches, faceplate etc - Hence my post here.
Agreed - but we are speaking with 2015 eyes and expectations. When it was made, it was probably regarded as the height of desirability!Yes If i made that, i would not admit to it……..There is no indication of manufacturer on any of the switches, faceplate etc - Hence my post here.![]()
It would be normal, and probably advisable, to use DP switches. You ought to check that your hob (and maybe even your oven) don't (can't) draw more than 20A, since otherwise 20A switches would not be suitable for that (and you'd be hard pressed to find anything larger than 20A - I suspect that's why I don't recall ever having seen a hob {and have rarely seen an oven} controlled by a grid switch!) You'd again have to check, but I would assume that the fuse is associated with the extractor switch, and that it is required.Right, thought I knew what I needed to buy to replace this but when it comes to the switches i want to make sure I get it right first time . . . Assume I need 5 x 'MK 1-Way 20A SP Grid Switch' but what about the fuse holder? is it required? Is it linked to the switches? Thanks all.
