Something has just dawned on me; If I am correct, BS7671:2008 requires all electrical work to be designed, installed, inspected and tested in line with the wiring regulations.
As far as I am aware, apart from the most simple maintenance jobs like replacing a light switch or a socket for like for like, electrical work needs a Minor works certificate to be filled out and completed after the work has finished in order to comply with BS7671.
That in turn means that when DIY'ers do electrical jobs like install an extra socket or install a new outside light, they would need to fill out a MWC and do all the required testing.
Now as the testing includes things like; system earth loop impedance testing, IR testing, R1+R2 impedance testing, etc... what I assume most DIY'ers won't have the tools or the knowledge to carry out; that in turn means the work they do won't comply with BS7671 right?
I bet most DIY'ers and even staff in DIY stores are not even aware of this.
Now while I am sure a lot of the DIY electrical work carried out by competent people is mostly safe, albeit untested; it does make you wonder what sort of issues go undetected due to lack of testing and adherence with BS7671 on DIY work.
Side note: If any on this thread are interested in seeing a tour of my shed/workshop; then see here: http://www.diynot.com/diy/threads/my-shed-workshop.437246/#post-3409964
Regards: Elliott
Regards: Elliott
