- Joined
- 23 Jun 2015
- Messages
- 6
- Reaction score
- 0
- Country
Hi all,
Thank you for taking the time to read my post.
We have recently moved into a premises that used to be two separate flats, each with it's own phone line. Now we are here the master socket for our line is upstairs, but we need an extension downstairs for the alarm system to connect to.
There is an old (disconnected) BT master socket downstairs which has a cable that runs outside to a junction box where the drop line meets the house. The master socket upstairs also runs outside to this same junction box where the drop line comes in. Ideally, I would like make use of all this existing cabling if possible, as running new cables would be a nightmare due to the distance and many thick walls between each socket.
Would it be possible to use a pair of wires in the existing cable which runs to our new master socket to run the signal back up to the junction box and connect to the old cable which runs downstairs? Or is there another solution which doesn't require running new cables?
I know work like this isn't allowed without a BT engineer, but i'd like to know what i'm dealing with before calling them as so far each engineer that has come to help us has been useless (many visits for 2 phone lines and 1 internet connection).
Once again thank you for reading.
Regards,
Oli
Regards,
Oli
