So I bought a property in 2012 and put it on rent till last week when I moved in.
Bathroom and toilet are separate rooms, with separate light switches and lamps.
Both lamps are flickering or dimming so I go into the loft space to have a look at wiring to see if there is a loose wire or break etc...
Find a fairly new box, with connector choc blocks inside. Earth sleeve is shrunk on some parts and looks charred in others...
Had a quick follow of wires best I can, looks like it's in a ring or middle of radial circuit, has only one switch wire ( only one switched live comes back). Feeding only a light in bathroom part. Can't see toilet part ( next room) as cold water tank appears to be sited on top of it...
Various times of use the light is noticeably brighter or dimmer in both rooms, however all other lights on the same circuit (landing bedrooms etc) all seem the same brightness.
There is also a fairly new but disconnected shower extractor fan isolator/transformer nearby which looks like it's been screw connected then removed from somewhere.
Any ideas what could be causing the dimming and heating issues? All screws are tight and already where when I opened the box to peer inside.
Pic of junction box attached.
