Hi
I am moving house and will be removing some appliances (Dishwasher, Fridge, Freezer, Washing Machine) which we cut off the plugs and hard wired into the outlets when we moved into our New Build property. The buyers have said they do not want to hard wire their appliances into the wall outlets and have insisted we replace the fused outlets behind the appliances with 13a & 3a sockets, in which they can simply plug in their own appliances. It seems daft to me since having them hard wired with separate switches above the worktop is a much better method, but hey ho its up to them.
For the appliances which are hard wired
but with a separate fused switch above
I am going to simply replace the outlet
for a non switched single socket. Since it is fused above I assume this will be ok.
My question is the switch above the worktop for some appliances
do not however have fuses and instead have the fuse at the wall outlet
. My question is how best to fuse this setup. Can you replace this outlet with a single 13a plug socket with fuse ? Do these even exist as I couldn't see any in B&Q only double sized sockets with a single socket and fuse and switch.
Any advice greatly appreciated.
Thanks in advance.
for a non switched single socket. Since it is fused above I assume this will be ok.My question is the switch above the worktop for some appliances
. My question is how best to fuse this setup. Can you replace this outlet with a single 13a plug socket with fuse ? Do these even exist as I couldn't see any in B&Q only double sized sockets with a single socket and fuse and switch.Any advice greatly appreciated.
Thanks in advance.
