Help with my soldering technique
So I took back the crappy torch and invested in a Rotherberger SuperFire 2. All I can say is WOW! It was pricey but you definitely get what you pay for. Soldering is now effortless and a lot neater! Thanks for all your advice guys, I'm feeling a bit more confident now I have the right tools and had a little more practice :)
Joints look good, but even the best looking joints can leak ( everybody gets leaks) the only way to know if a joint is good is to test it, if it looks good and doesn't leak, all gravy
For pressure testing I got some compression end caps, drilled and installed a tyre valve, then pump up with my little compressor. Worked a treat
Be careful, the energy required to compress air is much higher than water, end caps can blow off with force
tommy - I had the exact same problems tonight soldering some end feed 28mm. Solder would just bobble and drop off. I reduced heat to begin with and it helped a lot.
Luckily I found this thread and took the other advice, especially the 'heat away from where you apply the solder' and the solder will 'run to the heat' from Dan
After several practices I got a technique that works. I pressure tested mine to 1.5 bar using a dry test gauge.
Search google for 'dry test gauge'. Mine was about £30 and has a 15mm pushfit fitting. Also has the required Schradar valve so you can easily pump up using bike pump.
As I write now it's pumped up to 1.5bar and I'm waiting for 30mins whilst I have a well deserved beer.
It's easy when you know how, as they say :)
