Hi Guys
I understand that current regulation state that kitchen work is no longer notifiable unless installing new circuits.
I am in the process of ripping out kitchen ready for a re-fit and about to undertake 1st fix electrics (not me personally, I will be using a friend who is a registered electrician but who cannot self-certify)
My questions are -
1. I will be getting a GAS cooker (Rangemaster) so would this need its own circuit or is it normally just electric / duel fuel cookers that require their own circuit now? If so then putting in a new circuit to cooker (literally 1 meter from CU) would be notifiable?
2. My kitchen currently has a total of 2 double sockets. I plan on adding more double sockets above worktops and one below for dishwasher. (Washing machine and fridge are in separate room) Would it easier to just make a new circuit for kitchen as CU is actually in kitchen or shall I try and extend the current ring main (on CU it is downstairs sockets) could this cope with say 5 extra sockets in the kitchen)
Here are some photos to explain is further
This photo shows CU and 1 of the 2 double sockets above counter. You can see another socket in dining room which I could extend off through wall as cabinets will be an L shape around this corner in kitchen
This next photo shows another corner in the kitchen where the are no sockets, I wish to add 2 doubles here somehow?
The other corner which is directly diagonal from CU is where the second double is presently.
Here is a very rubbish plan -
Green - Existing socket
Blue - New
Yellow - Will be a FCU for dishwasher
The one green over by CU will also be where the cooker will be going so dependant on if it needs its own circuit then I could change this socket to a FCU and run a plug outlet below counter behind cooker? Also need to think about cooker hood...
The current single cooker I have now is plugged in to the double and as I say above the cooker will be going to the other side of room, gas line already there as meter is under CU and a line runs under cabinets up to boiler.
Any ideas?
New circuit or make use of what's there?
Notifiable work?
My questions are -
Blue - New
Any ideas?
Notifiable work?
