My 'just arrived' IP44 rated cabinet has a cable at the rear. The instructions show this cable being connected to the lighting cable feed by a simple 3 terminal screw block inside a wall void. There's very little space between the back of the cabinet and the wall; just about enough for a wall plate. However, with the wall being plasterboard to which tiles will be added, it's easy to create a void using a single gang dry lining box......but what cover can I use?
I've searched Screwfix, Wickes and Tool Station, but can't find a cover plate that offers a simple cable entry. I don't want a fused connection as any failure there will require taking down the 20 kg cabinet
Any suggestions most welcome.
Thanks.
Thanks.
