I do hope they were not trying to do that! It would kill the pump very quickly as the top bearing would not get any lubrication.I'm not sure they weren't trying for vertical...
The wire to the boiler is an output, it's what makes the boiler run. There should also be a wire from the HW cylinder thermostat.the inputs appear to be from the boiler and the orange wire from the three-way valve, and it was measured at over 240V when it tries to start, rock solid, no dip.
Is it an old pump (Selectric) which has just had the head replaced by a UPS2?I would say it's now sticking after a shorter and shorter period, also tapping the right spot on the back of the pump seems to get it to go straight away
