Texecom Premier 24 and Wintex questions
What will be the cost difference between installing a comip and a replacing the panel so I can use the app and stuff?
just plug the com ip onto a com port say comport 1, then you need to find what ip address has been assigned to the comip unit
thanks, does the comip come with a connection for a CAT5 cable then?
Do I just need to depower the alarm and then it will be obvious where this comport 1 is?!
Great, thanks for your patience!
Do I need to power down the panel to connect this I assume?
Also, anyway of getting Wintex to work on my Mac?
I use Wintex on a MacBook Pro, you need to either use Bootcamp or a virtual machine, I use Parallels and it works perfectly although using either method you still need a Windows license.
