Hi
Got a problem with a newly installed radiator.
The radiator is at the end of 14 metres of 15mm Plasic Pipe (its 22m plastic for the first 8m). We put a new radiator in by t'ing off an existing radiator pipe buried in the wall.
The radiator is quite large (5kw), the existing one is about 2kw.
Everything was working fine with the new radiator, so the chases were plastered over yesterday. I went to turn up the heating to get the plaster to dry and the new radiator isn't working.
Firstly I thought it just needed to be balanced, so I reduced the flow on the nearest radiators. That didn't work
Then I switched all the TRV's in the house, so that only this radiator was on full on its TRV. That didn't work but I left them all off for the steps below.
Then I took off the TRV and checked the pin and it looked fine, I swapped the TRV for another on that hadn't been near the plasterers and that didn't work either.
Then I added some water to the system to give it more pressure (about 1.8 cold in the end) and that didn't help either.
I put a boiler fixs in the pipes to the radiator to help with the installation to stop the need for constantly redraining the system which are now burried in the wall (I appreciate that this isn't ideal, but I am an amateur plumber so give me a break please!!). I thought the plasterers might have thought that it was funny to turn them off, to allow the plaster to dry evenly so I wanted to check that wasnt the case:
1. I closed the lockshield and the TRV and opened the drain/vent valve at the top of the radiator, this then produced a nice steady stream of cold water. Then I opened the lockshield and the flow of water increased, I took this to mean that there wasn't a blockage in the return pipe. ( I know its the return as it took longer to get hot when the rad was working)
2. I closed the TRV and the lockshield again, opened the drain/vent valve at the top of the radiator. Again a steady stream of water, which increased in flow when I opened the TRV. I took this to mean that the flow valve wasn't blocked.
3. Whilst I had the TRV opened and the lockshield closed, I left the drain to run for a few minutes and eventually the flow pipe got slightly hot. Hoping that I had cleared a blockage I opened the lockshield and instantly the inlet pipe got cold, like the return was at a higher pressure and the cold water flowed back into the inlet pipe.
Strange thing is that during the whole of the above (when all the TRV's were off and every single radiator pipe in the house was cold), the inlet and outlet pipes at the boiler were both boiling hot, which made me think that there might be a path of easier resistance for the water somewhere under the floor boards.
I am 100% sure that the TRV valve is the flow as I clearly remember it geting hot when it worked.
So now I am wondering if the pump is up to supply this radiator at the end of a long pipe. Its a Vaillant 937, had a quick look at the manual and it talks about two interesting things:
1. You can change the pump operation mode D.019 to run all the time:
Setting for operating mode of 2-stage pump:
0 = Burner operation = stage 2, Flow/overrun = stage 1;
1 = Heating + Overrun = stage 1, Hot water = stage 2,
2 = Like 1, but rotational speed during heating mode
depending on heating partial load,
3 =Always stage 2
4 = Rotational speed during heating mode depending on
heating partial load, otherwise always stage 1
Looks like 3 is the setting to have here?
2. Changing the bypass valve setting:
The boilers have a bypass valve.
The pressure is adjustable in the range between 17.0 MPa (170 mbar) and 35.0 MPa (350 mbar). Approx. 25.0 MPa
(250 mbar) is pre-set (mid-position). The pressure changes by approx. 1.0 MPa (10 mbar) each time the adjusting screw
is rotated. By turning right, the pressure increases and turning left decreases it.
Right-hand stop (turned all the way down): 35.0 (350) If the radiators do not get properly hot in the default setting.
Note: In this case, you must set the pump to the maximum stage
I know that opening the cover isn't strictly legit, but I am willing to give it a go to see if it helps. Any thoughts on what I have done and I am intending to do?
Many thanks for taking the time to read this!
3 =Always stage 2
