I suppose his answer to that will be that one would then run a 32A radial from the house!What if a 20A supply isn't enough?
Exactly. But for the average domestic garage 20A is enough.
That's the sensible approach, in my opinion. Here it's pretty much normal to fit garage receptacles a little over 4 ft. from the floor, that way when things like 4 ft. wide sheets of drywall or plywood get propped against the wall they're not in the way or hidden.how about metal clad sockets at chest height
That would save about £25.We did discuss the changes in the law in january, where all the boxes have to be metal? But it was cheaper on materials to have a plastic consumer unit if we have the work done in the next couple of weeks.
If using metalclad sockets, use steel conduit, not plastic.If you're using metalclad sockets, have a think about wiring them in singles in conduit rather than T & E stapled to the wall. Nice and neat, mechanical protection and protection from UV (if you get daylight in your garage) and not that difficult (in plastic)
Steel conduit is a much nicer job agreed, but it is much harder work especially if you've got buttresses and corners to get round. I could have laid hands on a thread cutter and a bending rig but I wanted to get the 25 metres (crossing 6 buttresses) done in a day. For a domestic garage, plastic is fine- not quite as pretty and nowhere near as strong but completely adequate for the proposed use.If using metalclad sockets, use steel conduit, not plastic.
Fair point, trouble is most Part P sparks will have done a conduit run at college (and maybe a pyro run as well) and that'll be the last time they did it. Commercial types aren't allowed to do domestic now (or rather they can but then having some spotty youth looking disdainfully at it will take the shine off things a bit)He is using an electrician, not DIYing.
Maybe he should find one who can do pyro..![]()
Pyro is not taught at college any more. I work with two young lads. One is qualified and 5 years in the job, the other is a third year apprentice. Neither of them knows how to terminate a pyro end. Two of the older electricians I regularly work with were taught it, but they wont work on it as they don't have the skills, experience or tools to do so.
I have a 50A supply in 16.0mm² SWA to my garage. I have a 9 way DB in the garage which in reality is too small for my needs and already has some doubled up circuits. A 20A radial without a CU or DB certainly isn't a one size fits all solution to garage supplies.
It's a pity the U.K. no longer has anything in between PVC conduit and heavy gauge steel. Here we have EMT (Electrical Metallic Tubing), which is a good middle ground and much easier to work than the heavy stuff where the strength of the latter isn't needed. We also have two grades of PVC conduit, Schedule 40 and Schedule 80. The latter is much tougher than U.K. PVC conduit.Steel conduit is a much nicer job agreed, but it is much harder work especially if you've got buttresses and corners to get round.
