How is it "subverting" the design of the installation? The equipment in question is a part of the installation.Do you mean the one I answered here?
BS 7671 does not say that attempts to subvert the design of the installation because the manufacturer has been unable to make a product which is intrinsically safe should be allowed.
What are you going to try and claim next? That a manufacturer shouldn't design a piece of equipment which draws 40A because it "subverts" your design of the rest of the installation by requiring something more than the 1 sq. mm cable you'd like to use throughout?
The wiring and associated switchgear are there to serve the appliances, and thus it's not possible that selection of those appliances can do anything but have some effect on the requirements of the rest of the installation. That's not subverting the design of the wiring, it's a natural consequence of the wiring being there to serve the appliances.
Fitted to the appropriate boss provided for it on the water heater.Fitted where, to what?I have a gas water heater in the garage, for example, the manufacturer's instructions for which state that a temperature & pressure relief valve of whatever rating maximum must be fitted to protect against the possibility of the thermostat becoming faulty or some other problem resulting in an excessive build up of pressure inside.
Of course it's for protection against certain faults within the water heater - What do you think a T&P relief valve is there for?Is it relying on that device for protection of itself against its own faults?Is that wrong? Has the manufacturer built something which is "so intrinsically unsafe" that it has to rely on that external device for protection?
Why do you think he shouldn't specify that it be fitted by the purchaser during installation?Why do you think that the maker should not integrate the necessary temperature & pressure relief valve into his equipment?If I were to remove the T&P relief valve and blank it off, "because the manufacturer shouldn't rely on it" and then a faulty thermostat resulted in the water heater exploding, do you think it would it be the manufacturer's fault for relying on that external device, or my fault for ignoring his safety instructions?
Why do you think they're not? (At least that's what you seem to be implying.)Why do you think that gas water heaters and pressure vessel protection are analogous to MCBs?
