But doing nothing is not "making reasonable provision".
To be fair, I don't think anyone is talking about "doing nothing". Rather, AIUI, the discussion is about doing the same things which, just a few years ago, would have been regarded as "making reasonable provision for safety". Since the law does not reference BS7671, I don't think it can be assumed that the law's view of what constitutes "making reasonable provision for safety" will necessarily have changed just because the requirements of BS7671 have changed.But doing nothing is not "making reasonable provision".
I'm not quite sure what you actually mean by "doing nothing."But doing nothing is not "making reasonable provision".
Because, as I have explained to you before, the requirement to make reasonable provision for safety applies to what you do, not to [what-is-already-there + what-you-add].Yes, and the status which arises from the action must be a result of that action. If you have made reasonable provision for safety, then how can the result be anything but an installation which is reasonably safe?
Of course you can, because you are only held accountable for what you do, not for [what-is-already-there + what-you-add]. If [what-is-already-there + what-you-add] is not considered reasonably safe because [what-is-already-there] is at fault, but [what-you-add] is OK then you have complied with the requirement to make reasonable provision etc.Conversely, if what you do results is an installation which is not to be considered (by whatever criteria) reasonably safe, then you cannot have made reasonable provision for safety.
So does that mean that you do accept the concept that something which was OK to be done yesterday may not be OK to be done today, and you do accept that even if there is incontrovertible evidence that someone did do that something the question of when they did it would be extremely important, and that their guilt or innocence would hinge on when they did it, not on the fact that they clearly did?In the case of some act which has explicitly been banned, yes.
Yes I did, but you are trying to pretend that I did not because you are still trying to conflate the status of an installation with the actions which were done in order to arrive at that status.But you didn't really answer the question:
Would you explain why you think people are going to believe you when you indicate that you really cannot tell the difference between assessing the overall status of an installation and assessing the actions of somebody making an alteration to it?Would you consider the installation as I described it to be reasonably safe?
I wonder how many times it has to be explained to you that the requirement for making reasonable provision for safety applies to what you do, not to [what-is-already-there + what-you-add] before you understand it?Or would you tell somebody that you couldn't form an opinion without finding out precisely when those sockets were added, so that if done on one day it was all fine and dandy but if done a couple of days later whoever did it was acting illegally, immorally, etc?
Why do you believe that I believe that?So then why do you believe that you cannot make reasonable provision for safety unless you follow every single regulation within BS7671 to the letter?
I wonder how many times it has to be explained to you that it is very common for things to change in a way that means that what was considered OK to be newly done yesterday is no longer considered OK to be newly done today and yet what exists today because of what was done yesterday is not condemned, and does not have to be replaced, before you understand it?And the fact that the committee responsible for those regulations itself doesn't automatically deem anything non-compliant with every one of the current regulations to be dangerous in any way.
Be that as it may, the same situation applies. Do you now recognise that it is far from unknown for what was considered OK to be done yesterday is no longer considered OK to be done today? How specific the statute is is irrelevant - what matters is that things have changed - do you still not see that?But in that case whether you, I, the judge, or anybody else considers it "safe enough" is beside the point, as there is a specific statute which makes it an offense to drive in excess of 70 mph.Perhaps a better simile might be driving on a motorway at 100 mph, the excuse being that there was a time when the speed limit did not exist, and many people drove at speeds greater than 70 mph without having an accident, so it must be safe enough.
That is also irrelevant - the guidelines have changed, and what the guidelines used to say was OK to be newly done is not what they now say is OK to be newly done.What we're talking about is nothing like as clear cut. We're talking about a vaguely defined requirement to make "reasonable provision" for safety, and a set of guidelines in the form of a British Standard, to which the statute makes no reference anyway.
On the contrary - PBC is doing just that. He is advising people to do nothing about the requirement to RCD protect sockets and concealed cables on the grounds that doing nothing used to be OK.To be fair, I don't think anyone is talking about "doing nothing".
Whilst compliance with BS 7671 is not formally required, that is the British Standard which relates to electrical installations, and to deliberately refuse to implement a requirement of it which is intimately related to personal safety but instead to do something which the standard no longer regards as safe enough to be continued to be done is not reasonable.Rather, AIUI, the discussion is about doing the same things which, just a few years ago, would have been regarded as "making reasonable provision for safety". Since the law does not reference BS7671, I don't think it can be assumed that the law's view of what constitutes "making reasonable provision for safety" will necessarily have changed just because the requirements of BS7671 have changed.
I am musing what the world would be like if people barely able to read, like you, and disposed to ignoring anything they do manage to read, like you, were allowed to write laws.I was musing what I would do if it was my job to write the legally-enforceable rules for domestic wiring alterations.
That might depend on whether you wanted your legally-enforceable rules for domestic wiring alterations to end up being several hundred pages long.If I wanted people to be obliged to fit RCDs whenever they installed an additional socket, would I write "All additional sockets must be protected by an RCD" or would I write "the installation must be reasonably safe?"
I can. But then that's because I can think.Can anyone think of the answer?
Yes, if the the British Standard which relates to electrical installations had such a requirement so intimately related to personal safety.And if I had written "the installation must be reasonably safe" and somebody claimed that those words meant "All additional sockets must be protected by an RCD," would that person be telling the truth?
...barely able to read, like you, and disposed to ignoring anything they do manage to read, like you....
...I can think....
As I recently wrote, since the legislation chose not to refer to (or require compliance with) that "guideline" (by which I assume you mean BS7671), the two are totally separate things - and one cannot assume that the view of law as to what constitutes "making reasonable provision for safety" necessarily has to change because the (not referred to) requirements of BS7671 have changed.That is also irrelevant - the guidelines have changed, and what the guidelines used to say was OK to be newly done is not what they now say is OK to be newly done.
I'm sure you must know what I meant, but let me rephrase that to be more precise then: If you have made reasonable provision for safety in that part of the installation you have added, then how can the result be anything but that part of the installation being reasonably safe?Because, as I have explained to you before, the requirement to make reasonable provision for safety applies to what you do, not to [what-is-already-there + what-you-add].Yes, and the status which arises from the action must be a result of that action. If you have made reasonable provision for safety, then how can the result be anything but an installation which is reasonably safe?
And similarly rephrased for preciseness: Conversely, if what you do results in that part of the installation you have added not being considered (by whatever criteria) reasonably safe, then you cannot have made reasonable provision for safety.Of course you can, because you are only held accountable for what you do, not for [what-is-already-there + what-you-add]. If [what-is-already-there + what-you-add] is not considered reasonably safe because [what-is-already-there] is at fault, but [what-you-add] is OK then you have complied with the requirement to make reasonable provision etc.Conversely, if what you do results is an installation which is not to be considered (by whatever criteria) reasonably safe, then you cannot have made reasonable provision for safety.
If you're using "O.K." in the sense of meaning legal, of course I accept that. Many pieces of legislation take effect from a certain specified date and what was legal yesterday can suddenly become illegal today.So does that mean that you do accept the concept that something which was OK to be done yesterday may not be OK to be done today, and you do accept that even if there is incontrovertible evidence that someone did do that something the question of when they did it would be extremely important, and that their guilt or innocence would hinge on when they did it, not on the fact that they clearly did?
How can you separate cause and effect when they are so closely interdependent? Let's keep it simple and forget about what you've just added versus what was already there. You're building a new house and installating a new electrical system from scratch, starting today. If you make reasonable provision for safety then the result must be a reasonably safe installation; if the result is not an installation which is to be considered reasonably safe, then you can't have made reasonably provision for safety. Do you dispute either of those two statements?Yes I did, but you are trying to pretend that I did not because you are still trying to conflate the status of an installation with the actions which were done in order to arrive at that status.
I knew I shouldn't have tried asking you for a straight answer to a simple question, because obviously you are going to refuse to answer it.Would you explain why you think people are going to believe you when you indicate that you really cannot tell the difference between assessing the overall status of an installation and assessing the actions of somebody making an alteration to it?Would you consider the installation as I described it to be reasonably safe?
When have I ever said that you become responsible for everything that's already there just because you add to it?I wonder how many times it has to be explained to you that the requirement for making reasonable provision for safety applies to what you do, not to [what-is-already-there + what-you-add] before you understand it?
Because your entire argument seems to revolve around BS7671 being the "relevant British Standard" and that therefore if it's reasonable to comply with it and you don't you can't have made reasonable provision for safety, etc.Why do you believe that I believe that?So then why do you believe that you cannot make reasonable provision for safety unless you follow every single regulation within BS7671 to the letter?
How specific the statute is is very relevant to the situation being argued here, because it is only your opinion that doing the work under consideration here is illegal.Be that as it may, the same situation applies. Do you now recognise that it is far from unknown for what was considered OK to be done yesterday is no longer considered OK to be done today? How specific the statute is is irrelevant - what matters is that things have changed - do you still not see that?
Guidelines are not law, as you've stated yourself plenty of times in the past. It is only your opinion that the specific guidelines under consideration in this example need to be followed in order to comply with the law. Except that you then don't even seem to want to allow the exemption that the guidelines themselves provide.That is also irrelevant - the guidelines have changed, and what the guidelines used to say was OK to be newly done is not what they now say is OK to be newly done.
Again, it is only your opinion that the standard regards it as no longer "safe enough."Whilst compliance with BS 7671 is not formally required, that is the British Standard which relates to electrical installations, and to deliberately refuse to implement a requirement of it which is intimately related to personal safety but instead to do something which the standard no longer regards as safe enough to be continued to be done is not reasonable.
Your personal opinion about this matter has been noted (many times).Whilst compliance with BS 7671 is not formally required, that is the British Standard which relates to electrical installations, and to deliberately refuse to implement a requirement of it which is intimately related to personal safety but instead to do something which the standard no longer regards as safe enough to be continued to be done is not reasonable.
