Or if you wanted to make it a legal requirement for new sockets to be protected by a 30mA RCD or better, and for earth wires to have green/yellow sleeving added, and everything else that BS7671 now requires for compliance with that standard, you could just write a law which says "Electrical installations must comply with every requirement of BS7671:2008 as amended to 2011" or whatever.If I wanted people to be obliged to fit RCDs whenever they installed an additional socket, would I write "All additional sockets must be protected by an RCD" or would I write "the installation must be reasonably safe?"
If the bureaucrats who drafted the legislation requiring "reasonable provision for safety" actually intended that should mean that work should comply in full with BS7671, then why didn't they just say so?
You do not have to be so personally abusive to people. Do you not realize that it does nothing to support your claim?I am musing what the world would be like if people barely able to read, like you, and disposed to ignoring anything they do manage to read, like you, were allowed to write laws.
There are plenty of other pieces of legislation which are hundreds of pages long, so I don't see why this should be excluded, not that I think it would be of any great benefit as a whole if that were the case.depend on whether you wanted your legally-enforceable rules for domestic wiring alterations to end up being several hundred pages long.
But as you keep referring to the "relevant British Standard," then as I said above, if the intent had been to force installations to comply with BS7671 the legislation requiring such compliance would have been no longer than the existing regulation that is the current Part P.
That's effectively how it works here: The NFPA publishes the National Electrical Code (generally with a new edition every 3 years), and states either adopt it as is or they derive their own state code from the NEC with whatever amendments they see fit. Then counties and cities adopt the state code, again with their own amendments if they think it necessary. So every local building ordinance doesn't have to set out hundreds of pages of detailed requirements itself, it only needs to say something simple like "Electrical installations shall comply with the California Electrical Code 2007." And then add exceptions or changes if relevant.
If the intent in the U.K. was that installations should follow BS7671, in whole or in part, then it would be quite possible to draft legislation which said as much, legally mandatory compliance either with the standard as a whole or with certain sections of it.
