toilet cistern query
25 Aug 2004
Cornwall
we have a push button operated cistern..the type with the two sections for short and long flush
it operates a cable which pushes into the cistern internals
the push button is mounted on the face of an enclosure and that part is easy to remove as its held with magnetic catches
we want to revert to an 'old fashioned' lever to flush and at full capacity..our waste outlet needs a bit of help to get all the tissue out!!
can this be done easily or does it mean a completely new cistern...which looks pretty hard to get into...to me anyway...as it goes down behind the pan and has sealer round the edge
can show pics if necessary
cheers
geof
Not really possible.
More likely the problem is that all flush valves now flush 6 litres.
This used to be 9 the 7.5 now 6 due to regulations and trying to save water.
What ultimately happens is we now have to regularly flush 12litres When 9 would have done the job.
Very unusual.
If you have a 6-9l cistern you need to make sure your bowl is also a 6l one and not an old one dating back 20+ years.
I have a similar issue and my flushing mechanism will be changed to a fluidmaster unit and the waste bowl fitted with a newer one.
Use a Fluidmaster with handle,each time you hold it down the flush will empty the cistern totally,
its an improvement on the two flush system
cheers
geof
thanks..that is what we noticed
Make sure your flush valve is set to a full flush, as most are not when fitted.
Andy
thanks..i have now set it to its highest to do what you suggest
Very unusual.
I have a similar issue and my flushing mechanism will be changed to a fluidmaster unit and the waste bowl fitted with a newer one.[/QUOTE
thanks...i think the bowl seems rather new as the bathroom may have been upgraded in the last few years...
i think that is what we want...the water rates down here are pretty high but we cant abide leftovers in the bowl....mainly toilet tissue which seems to float and take a while to soak up the water
do you mean this one?
http://www.screwfix.com/p/fluidmaster-lever-dual-flush-valve/57025
I can't make out from the photo if it has a syphonic action or a trap-door hatch
I have tried Flappers which have a powerful quiet flush but are sometimes said to lose their seal.
thanks...yes that looks like a good conversion...will follow that up
what is the best way to get off the back panel behind the pan...i think it is slotted and sits down over the pan outlet and is sealed with silicone.....i guess removing the seal and lifting it up might be the way....there are no fixing screws
ps the present cistern is plastic and in the void behind the toilet seat area...the push button flush is situated in a decorative wood panel...the whole of the sink and toilet are in a bathroom unit which has flush panelling..boxed in may be the correct description. the sink is set into a black marble effect worktop and this goes over the area where the cistern hides..
ACE!
cheers to all
geof
Usually fascia is held in place with something like this:
