- Joined
- 11 Jan 2004
- Messages
- 42,758
- Reaction score
- 2,641
- Country
It was but, in my experience, ovens do get a bit warm.
I find they get warmer if the number on the dial is bigger.
That's true but it did allow standardisation of calculations and related value tables.Thus they changed the specification on paper without requiring any physical changes on the network.
No - that's Winston.I assumed it was a joke.
thats not very nice Bas, its xmasNo - that's Winston.I assumed it was a joke.
In what way was that "politically expedient"?The change in the 1990's was an exercise in juggling the specified nominal voltage and permissible tolerances for the political expediency of being able to claim "harmonization" with Europe,
The result being that if you wanted to sell electrical equipment in Europe it had to be able to tolerate the voltage range across Europe.the result being a declared nominal voltage 230V but with an odd asymmetrical tolerance of +10/-6%, a range of 216.2 to 253 volts.
To be able to claim that the U.K. had adopted a European standard without actually doing anything except juggling with the tolerances.In what way was that "politically expedient"?The change in the 1990's was an exercise in juggling the specified nominal voltage and permissible tolerances for the political expediency of being able to claim "harmonization" with Europe,
Which it already had to anyway, before the change. So what?ban-all-sheds said:The result being that if you wanted to sell electrical equipment in Europe it had to be able to tolerate the voltage range across Europe.PBC_1966 said:the result being a declared nominal voltage 230V but with an odd asymmetrical tolerance of +10/-6%, a range of 216.2 to 253 volts.
But that's all it was anyway - nominal ±%.To be able to claim that the U.K. had adopted a European standard without actually doing anything except juggling with the tolerances.
No it did not - if a maker chose not to support a particular range he did not have to.Which it already had to anyway, before the change. So what?
I know perfectly well what it means. But leaving everything on the network as 240V +/-6% while saying "Ah, but we'll call it 230V +10/-6% now" was still nothing more than a mathematical juggling act to claim compliance with the new 230V European standard.Are you in the Winston camp of not understanding what the word "nominal" means?
ban-all-sheds said:No it did not - if a maker chose not to support a particular range he did not have to.
I think you need to spend more time trying to understand basic arithmetic.But leaving everything on the network as 240V +/-6% while saying "Ah, but we'll call it 230V +10/-6% now" was still nothing more than a mathematical juggling act to claim compliance with the new 230V European standard.
I did not say if he wanted to be sure of it working, I said if he wanted to sell it. There was EU legislation which meant that he HAD to make it compatible with the harmonised voltage standard.ban-all-sheds said:No it did not - if a maker chose not to support a particular range he did not have to.
If he wanted to be sure of it working in other parts of Europe he did, which is the point to which I was responding:
What's wrong with my arithmetic?I think you need to spend more time trying to understand basic arithmetic.
There was talk of widening the tolerance to +/-10% at one time, but last I heard that had been abandoned. Was there an EU directive based upon 230V +/-10%, and if so, did that get transposed as is into U.K. legislation, or with changes?ban-all-sheds said:I did not say if he wanted to be sure of it working, I said if he wanted to sell it. There was EU legislation which meant that he HAD to make it compatible with the harmonised voltage standard.
It was your comment about the "mathematical juggling act" which concerned me.What's wrong with my arithmetic?
Voltage harmonisation was a CENELEC thing (Harmonisation Document HD472), but the way it was (is?) to be made practical reality was to require equipment to tolerate the entire range. Not really a problem except for incandescent lamps.There was talk of widening the tolerance to +/-10% at one time, but last I heard that had been abandoned. Was there an EU directive based upon 230V +/-10%, and if so, did that get transposed as is into U.K. legislation, or with changes?
Obviously if you adjust the permissible tolerances you could declare it to be anything within that range if you wish: 235V +8 / -8%, 250V +1.2 / -13.5%, etc.It was your comment about the "mathematical juggling act" which concerned me.
But if they hadn't changed the declared nominal voltage, the tables wouldn't have been recalculated for 230V, surely?It was - but the related values (max. Zs etc.) were adjusted to be compatible with 230V therefore continued use of 240V would not give the correct answers.
Agreed - but harmonization was the reason and purpose.so there was absolutely no need to change it other than for usual case of "European harmonization" for the sake of it.
