Im currently building a niche in my bathroom as in the images below.
I want to put 3 spot lights into the top of the niche shining down from the top. there is about 75mm of space but i think a maximum hole size of 65 - 70 mm would be about right.
The house was rewired a month or two ago and the supply was installed for a light up mirror.
Ive spoken to the electrician and due to a change of layout, he is happy this supply can be used instead for some spot lights as its wired to the light switch not permanent live. plus have you seen the price of the mirrors with lights? what a rip off.
I went out and bought some 12v deck type lights with the plan to fit the power supply in the loft and then run the water proof cables behind the aquapanel. However when they arrived, you couldnt see any of the light they gave out. hopeless brightness.
so I wondered what you may suggest instead, ive been looking at IP65 and IP67 down-lights,
this https://www.yesss.co.uk/light-fitti...ted-downlight-satin-nickel-clear-50688-p22490 is an example of something ive seen which states it can be used in zone1 if protected by a 30MA RCD which my sparky says it is. Would these be acceptable? or would you go for something IP67 here where there is likley to be water splashes and the possibility of the hand hose spraying them?
thanks
thanks
