Hello,
As I understand it, when running cables in walls, the regulations stipulate that only cables buried at a depth of less than 50mm require protection? Although it would of course be sensible to protect cables buried greated than 50mm too as screws are getting longer these days!
If a cable was running behind a wall mounted cabinet - cabinet is 600mm wide, depth is around 140mm and the gap between the back of the cabinet and the wall is about 20mm - would this be within regulations?
Thanks,
J
Thanks,
J
