- Joined
- 21 Jan 2016
- Messages
- 4
- Reaction score
- 0
- Country
Hi All,
My wife and i are in the process of buying a bog standard 30s 3 bed semi. I need somewhere to work from home (not run a business, just work for my employer rather than travel to the office).
At the end of the garden there is a 16' by 16' double garage with off road parking for two cars. Parking is not a problem in our area (and in any case, we only have two cars).
I am thinking of putting a small (8 foot by 8 foot) office in the garage. I would first tank the floors and walls, then build a stud wall (think this is the right phrase) lined with a couple of inches of insulation. Same for the floor, and same for the ceiling. My father in law is a retired builder, reckons he can knock it up in a weekend, to building regs standards but has taken a - ahem - pragmatic view that "if you don't tell them they won't know because they probably don't apply anyway". The only external change would be to replace a current single glazed window with an external glaze. I might upgrade the external pedestrian door with one with better locking, but the roller door at the front of the garage would not be touched. There will be no toilet, water supply, etc. It's just a place where i will work for around 14 hours per week.
I'm not particularly concerned about impact on resale of the house, since if the new buyer has an issue, i'll just strip everything back to how it was before moving.
I understand that i will not need planning for this. However, i am confused about building regs as there doesn't seem to be a specific scenario described. If i were to build a wooden shed for working, for example, then the following would apply:
"If you want to put up small detached buildings such as a garden shed or summerhouse in your garden, building regulations will not normally apply if the floor area of the building is less than 15 square metres and contains NO sleeping accommodation."
That was what i'd read when we decided to buy the house. Now, though, i've started to read more about building regs and its not clear whether or not i would need this to convert part of the garage into office space. I suppose my worry comes from reading about needing to put foundations under the garage, maybe dig out and replace the floor, etc. Stupidly, i'd assumed that if the space could take the weight of two cars, it could take the weight of a couple of stud walls, a desk and a computer.
Does anybody have any experience to share?
